Change Currency: USD
Small sewing clutch with magnetic closures and 3 zippered pockets (sewing notions theme)
$90.00
Product Information
The size of this bag is 10" x 5 1/2" x 5"
Watch this video for details - https://youtu.be/ZlhyGMyv0qk?list=PLXPet7u5eWhvuoyU6CXYCaFpRnXMPzeu6
It can be used as a sewing supplies bag, cosmetic or travel bag, school/office supplies bag or any other small tools, instruments or supplies bag.
There are two invisible sewn-in magnetic snaps on the top panel to close the bag.
There are three zippered pockets inside; a small pleat on the bottom adds some extra room to each pocket making them a little spacier.
Pockets are not sewn to the bottom, so you can insert 8" x 4" quilters ruler under the pockets on the bottom of the bag, which makes using the bag more efficiently and helps to keep the bottom sturdier and in better shape.
Pockets are made of bright and colorful cotton fabric with sewing notions prints.
Multicolored zippers will help you to visualize what each pocket contains.
For the lining I used aluminized ironing pad cover fabric, so you can use it as an ironing pad for small paper piecing or other projects, where miniature iron is involved.
Fusible interfacing keeps the bag nicely shaped.
There are also four snap fasteners on each corner of the bag; when snapped the bag looks like squared box; when unsnapped (one or both sides) you can use the side(s) as a tray for your sewing notions and an ironing pad.
When open, magnets can be used as pin holders.
44" shoulder strap or 20" short strap on swivel hook and D-rings is detachable, fused with interfacing.
My original design.
You can also find this and my other patterns on Craftsy @ QuiltessaNatalie pattern store - https://www.craftsy.com/sewing/patterns/small-sewing-clutch-or-handbag/293278
Happy sewing!
Natalie Quiltessa
Product Code: SMABTMZN29
eCommerce by CubeCart
