Log In or Register
Change Currency: USD
Advanced Search
Enter your e-mail address to receive our newsletter
Your basket is empty.
Magnetic Seam Guide
$19.75
Out of stock
A ruler that measures squares in 1in, 1/2in, 1/4in, 1/8in and 1/16in increments - over 50 different sizes from 3/4in to 4 5/16in. It can be used for rotary cutting squares two triangle squares, and four-triangle squares (like the Precision Trimmer 6, only with a lot more square sizes). A ruler that measures squares in 1in, 1/2in, 1/4in, 1/8in and 1/16in increments.
$25.00 $22.00
$17.50 $13.00
$4.50
$5.75
Линейка с геометрическими шаблонами-прорезями, в уголках каждого шаблона есть дырочка для того, чтобы маркером отметить припуски на швы, окошечко-рамка особенно удобно для тканей с рисунком, можно отцентровать и выбрать направление, расположение или цвета.
$21.00
This ruler is a girls best friend. You will be able to cut perfect 60 degree diamonds every time. Cut diamonds in 1/4 inch increments without measuring. Simply place the slotted ruler on the fabric strip and cut in slots. You can cut 1 inch to 6 inch diamonds. Made in USA.
$17.00 $13.50
Create 5 different size pinwheel blocks using this one ruler. Complete details for fabric yardage, layout, number and size of squares are included on package insert. See how to use it on
$25.00
Линейка большая со слотами разного размера для волнистого края квилта, 18" x 6 1/2"
$8.50 $7.00
$20.50
$28.35 $20.00
eCommerce by CubeCart
